So I just had the alarm put in a few weeks ago and now the car has an intermittent misfire problem. It looks like it fires only on half the cylinders and on my Trans Gen II it shows 0 RPM when the car misfires. I took a temp gun to the cylinders to find out which ones are misfiring and it looks like only 1 cylinder per coil pack is firing, so I have 2 cylinders on one side and 1 cylinder on the other side that are firing. I am thinking either the ignition coil module took a crap cause I doubt that all the coils would go bad at the same time.... right? Im gonna double check the work the alarm people did but I do not want to take it back to them to check it out. I wouldnt trust them to diagnose a car even if its just double checking there work. I would rather do it myself.
But sometimes the car runs fine. Then other days I start it and it misfires like crazy! But it only misfires on start ups and then I cant drive it. If the car starts normal then usually I can drive it with no issues.
Anyone had this misfire issue before? Thanks!
