Jun 26, 2008 #1 D d0n_3d Boost is good. Joined Jul 14, 2001 Messages 4,740 Mine is stripped out and the stock bolt does not tighten anymore which has been causing my tranny to leak there. I want to tap it out one size bigger. What size should I tap it out to?
Jun 26, 2008 #2 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 you could try 1/4 20
Jun 26, 2008 #3 D d0n_3d Boost is good. Joined Jul 14, 2001 Messages 4,740 I could do that...I know the factory hole is metric...is 1/4 20 the next size bigger? If so then that answers my question.
Jun 26, 2008 #4 Royal-T-Ltd Well-Known Member Joined Jul 12, 2003 Messages 4,328 d0n_3d said: I could do that...I know the factory hole is metric...is 1/4 20 the next size bigger? If so then that answers my question. Click to expand... it might work ... i am pretty sure the factory is metric FINE thread so i think if you rethread with a std coarse you should be fine.
