Anyone have a stock chip and cal pak?
B J
Hi,
We are trying to diagnose a problem with some major ignition retardation. We suspect it to be the mod or the calibration chip. Does anyone have a spare set that I can use or purchase?
Thanks,
B J
Thanks for the response HT. The mechanic at Auto World wants to try a stock chip and a different cal pak to see if the ignition retardation disappears.
B J
I can't remember what the symptom was but if I remember it starts knocking off idle. It runs okay in limp home mode.
This is what is installed.
231ci V6 bored .030 over (109 block)
Engine Balanced & Blueprinted
Postons .030 Hypereutectic Pistons
Postons GN110T Cam 212in. / 206ex. @ .050 Duration
Ported Stock Heads (1.77/1.50)
Heavy Duty 100lb. Valve Springs
PTE-51 Turbo w/ .63 AR Housing
K&N Cone Filter
Chrome Plated Aluminum Intake MAF Pipe
Blue Silicone Turbo Hoses & New Up-pipe Hoses
Heavy Duty Adjustable Wastegate Actuator
Bosch 868 36# Injectors
Bosch Adjustable Fuel Pressure Regulator
Rail-mounted Fuel Pressure Gauge
SMC Alcohol Injection
Ported Stock Intercooler
RJC Power Plate (Plenum Spacer)
RJC Rocker Shaft Supports w/ New Rocker Arms, Shafts & Retainers
Postons 2-Piece 3" Downpipe
Ported Stock Elbow
Dual 2.25" Dynomax Super Turbo Exhaust
ATR 3" Stainless Steel Test Pipe w/ Dump Cut-out
High Volume Stock Replacement Radiator
Carter Heavy Duty Water Pump / 160* Thermostat w/ Billet Housing
Ramcharger dual radiator fan
Billet Aluminum Overdrive Water Pump Pulley
New Upper & Lower Radiator Hoses
Walbro 340 Fuel Pump w/ Hotwire Kit
Rebuilt Oil Pump
Oil Pump Booster Plate
RJC “Biggie” Oil Filter Adapter
New Upper & Lower Engine Oil Cooler Hoses
Fram PH11 Oil Filter
Rebuilt Alternator
New Dayco Serpentine Drive Belt
Exide Heavy Duty Battery
Vacuum Brake Conversion Kit
Alternator Bracket Torque Strap
New Heater Core
New Wastegate Solenoid & Boost Lines
Grainger Valve (not installed)
Chrome Turbo Heat Shield
Originally posted by B J
Hi,
Thanks,
B J
Hey Wes,
How's it going? I haven't been to this site for awhile, so I just noticed your post. You might want to swap calpak's to determine if that is the problem (maybe Paul might lend his for troubleshooting purposes....just a thought Paul;) :D ), but I wouldn't recommend using a stock chip for those injectors.
The stock injectors are 28#'s, whereas yours are 36#'s. Did the mechanic check to see if the knock sensor is functioning properly, or if it's torqued down to the proper specs? It's just an idea, since I'm sure that it's possible for the knock sensor to come slightly lose, causing KR.
HTH,
Keith
That's cool Paul!:) Wes, you might want to contact Paul, and troubleshoot with a known good calpack. If that corrects the problem, you can close the deal with him. Good luck!
Paul, so how's the conversion going? Are you custom fabricating your own headers? I hope it's coming along good so far.:)
