I bought my '87 GN about a year ago and the motor had a rod knock. I knew this already and had a new motor built. It has Champion Irons, PT-52, PTE Front Mount, Delphi 50's inj., Accufab 65mm TB, Poston almost stock cam, Poston Headers, Poston 93 chip for the 50's inj, Pat's 10" 3200 L/U converter..
The problem is the idle. This car won't idle worth a sh*t. Hunts and surges, acts like a vaccuum leak, but trust me I have done everything to find one, work at a dealership and have used the smoke machine numerous times, replaced ALL hoses, IAC sensor, etc. The car has never had anywhere close to 17 in. of vacuum @ idle. The most I can get is 10 in park, in drive drops even lower. Thought I found the problem a couple days ago, thintake manifold gasket seemed to be leaking. Replaced it and still hunts all over the place, replaced EGR valve, no change. I can't get the IAC to drop down to 15-20 counts with the idle srew in or out all the way. Unplugged the IAC and seems to run a little better. Also didn't throw a Check engine light while the sensor was disconnected. Car runs fine at anything over idle. Will surge anometimes stall coming to a stop.. . . I'm at my wit's end here, car is making me lose my mind!!! Only other thing I can maybe hear is a slight exhaust ticking from pass. header somewhere. HELP ME PLEASE!!
