Syclone0044
Full Street Trim
- Apr 7, 2002
Seems that Methanol is the second best fuel you can burn, second only to Nitromethane. According to http://auto.howstuffworks.com/question642.htm, "compared to gasoline, you can pump about 8 times more nitromethane into a cylinder of a given volume and still get complete combustion. Since nitromethane is not as dense as gasoline in terms of energy, so you do not get an 8-time improvement in terms of power. It is more like a 2.5-time improvement Still, you can double or triple your engine's horsepower simply by changing the fuel. That's a huge improvement!"
It just occurred to me where an easy source of Nitro could be located. I found a site http://rcclub.8m.com/index.4.htm, and it seems like Radio Control gas-engine Nitro glow fuel sounds very suitable at least in theory!! "10% Nitro" glow fuel is composed of 65% methanol (which we already know works and is safe), 25% castor oil (lubrication?) and 10% Nitromethane. I can easily go to my local hobby store and buy gallons of Nitro fuel in various Nitromethane percentages. Anyone tried this? It seems Nitromethane contains oxygen in it as part of the molecular structure and therefore acts almost like nitrous oxide in that it releases oxygen in the combustion process. NHRA Top Fuel dragsters operate on Nitromethane (and methanol) so clearly big power can be made with it. What are the drawbacks? Would a small percent be safe to try out on a stock GM gasoline motor? I've had fantastic success injecting many many gallons of 100% methanol so far up to the 530HP range on a stock 262CID longblock.
Josh Straub
1991 GMC Syclone
11.79 @ 114.18, stock longblock w/chip, PT-51 turbo, SMC alcohol.
Josh Straub
1991 GMC Syclone
