Anyone make an ECM relocation kits
BJM
Senior Member
Does anyone make a kit to extend the main ECM harnesses to a different location? I am tired of pulling out the kick panel all the time.
If you're pulling the ECM out just to do chip changes, I might have a suggestion for you...
Caspers sells a PROM relocation cable. Basically, it's a 3-foot ribbon cable that plugs into your PROM socket, and has a recepticle socket for your PROM chip. My ECM is sitting happily in the kick panel, and the PROM now resides in the glove box. To change chips, I just open the glove box door.
Hope that helps.
That sounds perfect. I checked out Casper's site and didn't find anything like that.
Give John Spina at Casper's a call tomorrow.
He's got your siuation covered! :)
Thanks, I just found it using the search function. Do you have to protect the relocated PROM from EMI?
At the time I ordered mine, it was a "Special Item" on their web site. I just looked, and I don't see it any more. Hopefully they are still making it.
I would suggest calling them.
Good Luck,
For sure!! Better safe than sorry!
Using some anti-EMI sleeve-foil from a computer supply store here.
John will have something similar, so mention it when you call.
