Anyone running >.532" lift on a production motor?
Probably want to look at rocker arm to valve stem contact point in an over the nose cycle to make sure you don't get out to the edge too far.
lift
I/m running .520 lift on exhaust side with production heads..500 on intake--- the guides were already machined down. Using Comp Cam 941 spring. This is getting close to max.
I'm running a new setup on the car for a few months now:
PTE 218R flat tappet cam with 1.65 T&D's on "8445" ported production Champion heads.....
with a 1.50 rocker arm the cam is spec'd at .478/.481" lift.
with a 1.65 T&D the cam is .549/.553" lift unless my calculations are incorrect. No problems as of yet.
I'm still running the stock turbo.... and I don't think it works very well with this huge cam as the car isn't running as fast as before with a KB 208/208 .460" lift cam that was just as noisy.
-GNX7
Someone told me (can't remember who, sorry :-() that about .530 is where you have to start getting nervous about valves touching the stock pistons, as well as the guide-retainer stuff and coil bind that others have mentioned. A little clay would give a lot of peace of mind if you will have the heads off when the cam goes in.
I run a 218 roller w/ .536 lift..ported iron TTA heads and no probs for over 3 yrs.(well, valve train thats is)
