problem found!
Well,I swapped my ecm today with a known working one with a stock chip and it would only go to 15 or so psi but felt sluggish.I put the hypertech back in and it does not have any boost control coming in at all, whatsoever.I stab the throttle to the floor for a half second and it PEGGED the 25 psi vdo gauge!!I am certain it is the hypertech chip.Here's the funny part,except for the boost problem the hypertech has exellent response and driveability over the stock chip.So I hooked up the wastegate tuner style and nipped a little of the rod off and got it to peak at 15-16 psi with real good spool.I am going to leave it there now until I get the pump and injectors which are horribly overdue.The..I will take it take the track to see what it is doing,It is pulling pretty good and fries the tires from a 15mph roll.It seems fine without the chip contolling the boost seems more steady to me,I may stick with this setup if the numbers are good.
