Anyone w/ gn1 valve covers???
Maltman
Quick ?....What do we do with the EGR mount?
If you have these valve covers, then you must have found a problem with the new height....adapters, relocate or what?
Mark
The egr mounts to the intake. I had no clearance problems. Not sure what you mean.
sorry,
the egr part which mounts to the manifold and the stock valve cover bolt....it is near the coil pack.
I'm guessing that everyone simply leaves it unbolted, but I was thinking that might look kinda cheezy since I'm putting some much time into everything else
Mark
The egr solinoid is mounted to the intake as well, just bend the forks over where it would attach to the valve cover, then bend the whole braket over a little so it rest close to the valve cover, it still looks good and is hardly noticable.
