BlackBeauty
- Dec 15, 2001
Hey folks, I'm trying to tune, it's tougher than everyone makes it sound. I went to the track and believe my car was set up for high 12's (I will list mods below), but all I could get was a 13.8@100 and 13.9@100. That was with a power-brake launch but no boost. I then thought, "Well people launch with 15psi, so I'll try 5psi on my 275/60/15 BFG DR's" and that was a disaster, just spun half way down the track till I let off.
My 60's were 2.1 and 2.2, but even though my launch wasn't good, shouldn't I be trapping higher with these mods (properly tuned)?
adj. fuel pressure regulator (45psi line off)
307 fuel pump & hot-wire kit
K&N cone filter
alcohol injection (turn on ~13psi, pump speed was 7)
Hooker exhaust
Thrasher 92 chip
boost gauge
knock gauge
ScanMaster 2.1
DeQuick's radiator re-core
adj. wastegate rod (23psi)
torque strap
I didn't have an airbag at the time, but I got one since then (along with AC Delco R43TS spark plugs) and got worse results at the track. If anyone has a similar set-up, let me know what you have your adjustables set at. Thanks.
K&N cone filter
Hooker exhaust
Thrasher 92 chip
boost gauge
knock gauge
ScanMaster 2.1
torque strap
