Anything I should replace
NoVA_87_GN
I’m working my way through the car. As you can see by the pic, got a bunch of parts out while I’m cleaning stuff up. While I got access, is there anything that I should consider replacing?
Water pump s hose, it's cheap and easy to get to now, yours looks a little swollen. Check the wp outlet while it's out. Mine was plugged and was causing a no heat situation I couldn't figure out.
I would replace both upper and lower radiator hoses as well. If you do choose to replace the timing chain, it would be a good opportunity to replace the water pump as there not very expensive.
Clean the negative battery cable and where its located. Check the ground cables on the back of the block if you can. Make sure they are clean and secure. Remove the coil pack and bracket and its easy to get to them.
Get the fabric tape out and wrap all of the wires, those should not be exposed.
Check all of the connectors for the clips to secure them. Caspers makes a kit to replace all of them.
It's easy right now when you have the space.
