Sep 25, 2007 #1 R RUQWKNF27 Active Member Joined Apr 3, 2003 Messages 1,892 I got some TA headers that came with gaskets and I already have some Felpro 1400's can I use both?
Sep 25, 2007 #2 8 87NAT In Between GN's Joined Dec 24, 2005 Messages 3,058 One set of 1400's should do it. If not then you have something that is not straight causing you to have leaks.
Sep 25, 2007 #3 R RUQWKNF27 Active Member Joined Apr 3, 2003 Messages 1,892 Actually I have not had any leaks . Its just I have already Hi Temp Red the gaskets to the headers I guess I could pull them off and go ahead and use the 1400's.
