Does anyone have the website for the guy that builds the killer AOD trannys that can handle high hp? Had it but lost it.
My predicament is that I have rear disc brakes, and need to run a trans-brake tranny to be able to build boost on the line as the rear tires turn at 3lbs boost. I want a trans-brake and automatic shifting, and the 200-4R will only live a little while for what I need. A TH-400 is out because of the manual valve body. So, I'm not too proud to run an AOD with trans-brake if it will hold up. I thought I had the site saved, but can't find it.
Anyone have any input on these trannys, good or bad? Anyone know someone who has run them? TIA.
