meanchicken
gallo vicioso
- Oct 6, 2007
I learned some things today whiole climbing Hwy 2 in my GN....
Apparently...Turbo Buicks don't like altitude
Apparently...Turbo Buicks don't like altitude and high temps (220-237) at the same time
Apprarently....they also don't like the above while going uphill
Apparently....all the above together will possibly cause the buggers to vapor lock and leave you stranded on a lonely desert mountain hwy where there is no cell phone coverage...
hmmmmph...
Who knew?
Thank you Sytech for coming back 6 miles down the hill and rescuing me. Car was misfiring and chugging to a stall at low rpm. It would start back up, idel for a minute or two and then sputter to a stall again.
Before Sytech came back to help me, my buddy and I had tried a few things in a panic. Unplugged the MAF...no change...unplugged the TPS....no change....fixed a loose ground screw near the battery....no change...pulled my alky chip, turned the boost down to 13 lbs, turned off the alky, put the non-Alky TT chip in...of course...no change.....
Know what else I learned once I got home and reset my tune.
Apparently....if your spark plugs are loose in their sockets and the gap a little too wide (0.35 instead of 0.32)....it'll contribute to the above issues and really rob your power....huh.....
Who knew?
Sytech taught me this on the road side on Hwy 2 as we pulled, inspected, cleaned and regapped my plugs during his rescue mission. They were all kinda loose. I guess I was too gentle when I installed them 8 mos ago.
Once I got home, put my alky chip back in and turned the boost back up to 18 lbs...I took it our for a romp to be sure everything is back to normal....and the bonus is....the car feels a ton stronger than it did at 19lbs before all this happened.
Hey Spoolfool....I think I might now be able to break that 76 mph barrier in the 8th we ran into a couple weeks back while we set up my Alky tune. Butt dyno says so. I even beat up on a Porsche Cayman S to be sure. They are supposed to be mid 13 cars....I started from behind him at a light. He took off and I was passing him with ease before we hit 75mph:biggrin:
I'll hook up the laptop and do a few pulls in the next couple days and let you know what the direct Scan says.
Pappa Lou....I promose not to hurt the motor before bringing it to you for that work.
hmmmmph...
Who knew?
Who knew?
