I currently have 30 lb green stripe and am wondering if they are big enough for my setup or should I go with new 50 msd's. If you say the 30's are big enough, when would be the need to go larger.
Enigne stock except for
1. RJC powerplate
2. 160 thermostat
3. hot wire kit and Walpro
4. Alky kit running 23 lbs boost
5. K&N open cone filter
6. Turbo tweak alky chip
7. 100 lb valve springs
8. new timing chain
9. Scanmaster shows around 1.5 degrees of knock on the 3rd to 4th shift and O2 readings average 850 to 880
Many thanks
1. RJC powerplate
2. 160 thermostat
8. new timing chain
Many thanks
