art carr 200r4
buickturbot
i bought this buy said he put 1000 miles and it started messing up so he put his stock one back in.could be something simple don't know much about transmissions. it's a art carr extreme trans goes for $2700 and most likely not a brf.it does have a stock pan not the deep one. this is a brf trans.how like to get$1200 i'm in mass.perfer pick-up
might ship at buyer expense
here's what it comes with
200 4R EXTREME TRANSMISSIONS RECEIVE THE FOLLOWING PARTS:
Super Rebuild Kit featuring with extra clutches where applicable (12251), high output pump assembly (12080) which includes heat treated stator support shaft (12275), and the billet 10 or 13 vane rotor kit (17701 or 17703), super intermediate drum with hardened shaft (12278), heat treated sun gear shell, new updated 2nd gear servo (12279), automatic Hi-Tech valve body kit is installed (12001)
Trans
I can't give you a grand for a troubled trans if your willing to take less a lot less. Then you can tell me if it comes with a converter & if so what is the stall on it ?
