SignUp Now!SHADOWII said:Have you read the sticky above? They give you some ideas. Also, you might consider Chris' manual on the 200. It runs about $70.00 from CKPerformance.
turbojoe1 said:Looking to strengthen things up and get more out of her.
Any suggestions/ kits out there?
Thanks Joe
turbojoe1 said:So far all i've bought for it is a super servo.
I have also read that a deep pan, filter and pick up kit will help
Thanks Joe
monster in a box rebuild kit in mine
I hear ya, im looking leaving hard and shooting for 25+ psi with mods.
I have dropped 400lbs tho
Thanks Joe
Grumpy said:whats in it ???
▪ Gaskets
▪ O-Rings
▪ Lip Seals
▪ Sealing Rings
▪ .500 Boost Valve
▪ Friction Clutch Plates
▪ Steel Plates
▪ Forward/Direct Performance Clutches
▪ 200-4R Filter
▪ 200-4R Heavy Duty Kevlar Band
▪ Teflon Pump Bushing
▪ Delco Front Seal Retainer Clip
▪ 200-4R Superior Shift Reprogramming Kit
▪ Hardened Pump Rings
▪ 200-4R Heavy Duty 10 Vane Rotor Gear
▪ 200-4R 10 Vane Rotor Guide
▪ 200-4R High Rev Vanes
▪ 200-4R Heavy Duty Throttle Valve Spring
▪ Heavy Duty Sun Shell
▪ High Performance Billet Servo
▪ New TCC-Solenoid
All for 460. Free shipping
TRY-ME!!!
blackazz said:▪ Gaskets
▪ O-Rings
▪ Lip Seals
▪ Sealing Rings
▪ .500 Boost Valve
▪ Steel Plates
▪ 200-4R Filter
▪ New TCC-Solenoid
TRY-ME!!!
