Atlas Rotisserie with all adapters!
6togo
I am done using the rotisserie i bought a few months ago and dont have space to keep it. It is a Atlas brand with rams on both ends for easy lifting of body's and frame plus it has hand crank system which rolls the body very easy not manual labor! It is in good shape besides some paint on the frame fingers and a few scratches plus it has all the adapters to pretty much work on all types of cars and trucks! Here are some details and pics in action!
This auto body rotisserie is great for anyone wanting to restore a car or truck body or frame. The rotisserie allows a full 360º of vehicle movement by just turning the crank. When the vehicle is properly mounted and positioned, the Atlas Auto SPINS allows the operator to have easy access to all parts of the body for welding, sandblasting, or any other work that needs to be done. This unit is adjustable not only in width and length, but with two hydraulic rams, is also adjustable in height. The two hydraulic rams make it easy to mount and lift the vehicle so that it can be rotated into the proper position.
The two hydraulic rams also make it easier to mount an auto body; lifting the body or frame straight from jack stands to the desired working height removing the need for any other equipment. The rotisserie is also easy to roll because of the three (3) swivel caster wheels on each end. This versatile auto rotisserie is a must have for any hobbyist or professional restorer.
CAPACITY: 3000 LBS.
WIDTH (MOUNTING BRACKETS): 14 1/4” –48 3/4”
WIDTH CAPACITY (CAR OR TRUCK BODY): 85”
WORKING HEIGHT: 20 1/2” – 48 1/2”
WORKING LENGTH: up to 19’
CEILING HEIGHT REQUIRED: 8’
WARRANTY: 1 YR
THICKNESS OF STEEL 1/8"(9 GAUGE)
CONSTRUCTION MAIN STRUCTURE 3"X3" SQUARE TUBING
SHIPPING WEIGHT 600 LBS.
I paid $1150 for everything and would like to get $850 for the setup!
