Originally posted by 87LtdT
If you have a 3" downpipe and 2.5" dual exhaust, the downpipe is the choke point in the flow system...a flow restrictor if you will. Dual 2.5" exhaust have a 39% greater flow area than a single 3" downpipe.
So if you have a 3" downpipe you will get no performance gain from a 3" dual exhaust in place of a 2.5" exhaust...in fact you might suffer a bit due to the extra weight of a 3" dual exhaust. However, it will sound different (don't know any details here)....
HTH, Bob
In pure theory, what you're saying of course would be true, but we live in the real world, and gains are common when making such a change.
Simply because exhaust system back pressure is still reduced even when going to the dual 3" system.
Cross section area isn't the only factor involved, but lot's of folks like to trot it out anyway. It would be if the pipes in question were perfectly straight.
But they're not. Take a look under there. See all those bends and curves? Everytime the flow of exhaust has to make any kind of a direction change, even a subtle one, there's going to be restriction added to it's flow. Restriction equals backpressure.
Backpressure after the turbo is just exactly what you don't want. Not any of any kind (as apposed to N/A engines which seem to like some).
Ideally if one could reduce the post turbo backpressure to ZERO, that would be perfect. But not acheivable in a street car application, so minimizing it as best we can is the best way to attack it. That means mandrel bends, easy curves (as best as can be achieved), larger pipes, if mufflers are used, they should be of the straight through variety, with perforated inserts(not punched), no we're not talking glasspacks here
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
