SignUp Now!I have the wide chrome piece on top of the doors on my car and looking at them I cannot figure out how the dew sweep comes off, they look like their all one piece molded in.. if anybody has any pics I would like to see how they come off so I can replace mine as well..
I also have the standard chrome skinny ones I bought but they are going to look dumb if I use them so if anybody has the ones I need and are willing to trade or sell them let me know.
Morbid. You have the wide Limited moldings. No drilling needed. After you remove the 7 or so screws that hold the assembly to the door, the rubber will seperate from the chrome. 20674283-20674282 will not work with the Limited wide molding. Those are for a GN/WE4/W02 application. The Limited is a two part molding. One piece is the rubber and the second piece is the wide aluminum molding. You reuse the wide aluminum molding. It has a channel that fits over the rubber part. The correct part numbers for the Limited rubber dew wipes are RH-20674276 LH-20674277.
Both styles interchange. You may have to clean the top part of the door where the wide molding used to sit. And the 84 GN/T-Type used wide black Limited style dews instead of the skinny black dews used on the 85-87 models.
