Hey Craig,
I would like your help please. I have had my ecu looked at twice and it is now working I think. the little piston and rod is coming up on the screen now and the ind. cly control will hold the settings after a run now but I can not tell that it is doing anything to the motor. my cly 4 runs really hot and lean and cly 5 is cool and black. I have added as much as 20% in 4 and -20% in5 with no change.
i have to run my motor so lean (about 12.0-12.1) to keep the overly rich clys from skipping and not running good down track that I am hurting the motor slowly. Can I call you and see if you can help me with this, I have tried to get pte to help but they say they have seen the same thing but dont know what to do.
also the timing settings will not stay set after a run so I dont know if it is working.
thanks richie
thanks richie
