Autometer dual guage pod for A-pillar
Warp6
Mine since '92
part number 10400. Anyone using this? How do you like it? How's the fit and finish?
I'm not sure about the Auto Meter piece, but I've got a new dual gauge pod from Poston's. Let me know if you want it and I'll send it on up. Thanks Craig.
Ive got one and I dont like it. To install it, you have to drill 4 holes through the gauge holder and the A-piller. Then they give you these little plugs that you put in the holes that you drilled. If you make a mistake, it is nearly imposible to pull those plugs out without breaking them (I know this first hand). I ended up using double sided tape and a small screw to hold it on. Needless to say, this is not a simple instalation. As for the looks...well, it looks like $#!@ to me.
Take my advice, dont buy it unless you wat the ghetto GN look :(
BOOSTD
does anyone make a complete A-pillar replacement that houses 2 guages?
i got mine from ramchargers
dont know where they got it from or what not... you just screw it in right over the existing pillar plastic piece and looks great...
i like it very much
easy fit and it was pretty cheap!
Or you just drill two holes in the pod and screw it into the existing holes in the A-pillar. ;) I think it fits and looks as good as a ricey pillar pod can.
I bet most vendors are reselling the autometer pod.
A-Pillar Gauge Pod Source
Try LoTek. They are located in NC near Raleigh. They are painting a 3 gauge a-pillar and a 2 gauge t-top unit for my 84GN.
Conrad Carter
My Autometer pod fits very well. I drilled one hole and lined it up with the top screw on the pillar and then used super sticky 3M tape to hold the bottom and then painted the screw head. I don't think it looks bad at all.
