The reason you want it in front of the turbo is because it'll receive more consistent, and meaningful readings there.
After the turbo, is less consistent because the turbo extracts heat from the exhaust stream to do work. Problem is, the amount of heat removed isn't consistent. It varies widely with load conditions, etc. The temperature drop could be 400º or more, sometimes less.
Some of use don't just use the EGT at WOT, it's also useful at cruising and light load conditions, to check mixture changes, etc. so not knowing exactly what the temp drop is at all load conditions makes that kind of tuning useless.
