Autometer Instrument Cluster and Gauge Pods
Pox
Neither small nor chicken
I have a monte carlo instrument cluster that has been redone to carry four 2 1/16 gauges and a 3 1/8 tach and speedometer all autometer ultralites. I also have a 2 gauge center console pod and a 3 gauge a-pillar pod. All gauges have about 500 miles on them.
The gauges I have are all electrical excempt the speedometer
Speedometer $170
Tachometer $80
boost $35
oil pressure $45
oil temp $35
water temp $35
fuel pressure $170
egt $100
air fuel ratio $45
volt meter $35
fuel level meter $30
I can email you pictures if you would like. I will try to post some. Also, I will try to add part numbers later. I will probably be posting them on ebay soon.
3 Guage A Pillar Pod.
Holds What Size Gauges, Color, Does It Screw On To Existing Location?
2 1/16 gauges, you may need to drill holes depending on application
They do include the sending units. I'll send those pics out.
Pox said:
Speedometer $170
Tachometer $80
oil pressure $45
oil temp $35
water temp $35
volt meter $35
im interested in these gauges. whats the best you can you do on them? also can you get the part numbers?
Part # Gauge-Type Price
ATM-4493 Speedometer $170
ATM-4497 Tachometer $80
ATM-4301 boost $35
ATM-4353 oil pressure $175
ATM-4347 oil temp $35
ATM-4337 water temp $35
ATM-4327 fuel pressure $45
ATM-4344 egt $100
ATM-4375 air fuel ratio $45
ATM-4391 volt meter $35
ATM-4314 fuel level meter $30
$750 shipped if you pick up everything as a package
Sorry, mis-typed prices
ATM-4493 Speedometer $85
ATM-4301 boost $35
ATM-4353 oil pressure $45
ATM-4327 fuel pressure $175
ATM-4344 egt $100
$700 for everything and the pods and dash are included
Can you give me a deal on everything but the dash, EGT, and volts guage?
I'll take the Boost, Water Temp, Air/Fuel, Speedo, and Tach.
Antagon, I'm sure we can work something out. I am giving multiple buy's priority on choices: i.e. the more you buy, the cheaper it is and the more likely you will get what you want.
Well it's either these or something else I've been eyeing, so please keep me posted :)
