Autometer Wideband Install Question
wiseman
I just purchased an Autometer Widebad, P/N 5978 and the instructions state to install it 4-5 inches from the turbo. From what I have read, normally GN's need them installed 18 to 24 inches from the turbo @ 10 or 2 o'clock. Which one should i go with? The manufacturer's distance or the normal distance?
Thanks in advance.....
As far down as is comfortable. At least 12".
Sent from my DROID RAZR MAXX HD using Tapatalk 2.
Thanks for the response. I welded the bung a little before the last bend before the cutout. It turned good, thanks
The autometer gauge has a Brown Wire in its harness that is for the Optional Peak/Recall & Warning WOT Switch. It connects to the Wide Open Throttle Switch and Is required for the Peak Recall Functionality. Do I need this option or wire to be hooked up? If so, which wire on the TPS do I hook up to?
The Brown Wire(Optional Peak/Recall & Warning WOT Switch): is an option if you want to use this but you need to install a micro switch switch if you choose to do so. I have the same Auto Meter wideband and I don't use the brown wire, But I did place the mounting sensor as per Auto Meter instruction: "Turbocharged applications should have sensor installed 4-5" after turbo on the down pipe".
Thanks for the input, looks like I will not be using the Brown wire.
I have already installed the bung. I would have to.get another bung welded in to place it per the manufacturers instructions. I wonder if my readings will be off or wrong if I decided "not" to move the sensor 4-5in after the turbo and keep it where it is?
