aux transmission cooler.
ulose2av6
does anyone have a diagram on how to plumb in factory transmission radiator cooler with an aux transmission cooler. is the bottom line the feed line and the top the return line. not quite sure if I missed up the loop. thank you.
That picture doesn't look correct.
The hot tranny fluid should flow into the bottom of the cooler & out the top on both coolers.
Maybe I'm just looking at it wrong. :confused:
