Hey guys,
To make a long story short, I curbed my car pretty bad recently while trying to avoid hitting a moron on a bike who rode right out in front of me. At first I thought I had just damaged the rim, but on the drive to get the tire mounted on the new rim, my friend driving behind me noticed my tire on the side of the damage (pass. side) was wobbling pretty bad. After getting the new wheel/tire mounted, the wobble was still there. On inspection, I found my pass. side axle was bent when the bottom of the rim slammed into the curb. So far as I can tell, the differential itself isnt damaged (no noise, or vibration, or exsessive side-play on either axle), though this weekend I am going to pull the cover to visually inspect and make sure it didnt get too banged up. so far it looks like it's just the one axle that got bent, or maybe even just the axle flange got bent. Either way, the axle needs replacing.
Assuming the differential is fine and all i need to do is replace the pass. side axle, how do I do this? I am very machanically able, have worked on a lot of car before, and have a well equipped garage to work in, I have just never replaced an axle before. Is it particularly tricky on our cars? Also, does anyone know what a good source for an axle would be? I don't have tons of cash for this, so if this is something I can likely find in a junkyard, that would be great, but what years/models of cars should I look for? Essentially I'm looking for any help or info on replacing an axle on my GN, and any suggestions or help would be VERY appreciated. This is my daily driver, so the sooner I get this car back on the road, the better; bumming rides and public transportation doesnt work so well when you work the night shift
thanks in advance for the help!!
