Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
re-coring the radiator so it may be a good time to consider adding an aux. trans cooler. keeping radiator cooler...
not interested in coolers using barbed fittings and hose clamps. plan to use -6an hose and fittings/adapters.
70273 (aka Long/TruCool L7B) => 11 x 5-3/4 x 1-1/2 rated 15K BTU
70266 (aka Long/TruCool M7B) => 11 x 8 x 1-1/2 rated 20.5K BTU
old B&M catalog cites small block - greater than 3200 # with 2400 rpm stall converter to use the 70273
mounting will be similar to GNX cooler using custom brackets attached to existing radiator support holes via u-nuts/speednuts.
searching old threads on this topic yielded a pic of a 70266 installed as I'm planning, but that was for a modified car.
70266 cooler is the layout size I'm looking for...not much of the Pro-Lite 350 hose would be exposed and the 1/8" stock for the brackets lines up well with the radiator support existing mounting holes. similar sized coolers at 3/4" thick all use hose barbs and clamps - not what I'm looking for.
Performance wise, one day I will go thru the trans but have no reason to go to a higher stall converter. I could replace the factory prom with a TT street chip - I don't like the amount of timing in the factory chip with today's pump gas, even at 14 # boost. With TT (and corresponding mods), it'll run at 16-17 # boost
Is the 70266 cooler TOO MUCH cooling capacity for a stock converter? Thanks for your $0.02.
