Well hi guys , been a long time since I've been posting here about a running car. Finally got a rebuilt block in the car after spinning a crank bearing and she's not running properly. Starts up pretty fast and idles good for about 10 seconds then the idle gets ruff. Set the iac and tps twice now and have checked for vac leaks ( car has a front mount I/c I just built). I pressurized the car from the throttle body and found one small leak and fixed it. Took the car out for the first drive and it didn't like off idle throttle or boost past 5psi . After 5psi the car would feel like it was loading up and slowing down with more throttle input.
Car has new plugs but the old wires (only ran them 2years before the car got put away). New fuel, set the cam sensor per gnttype, any ideas guys I'm just getting back into the car after all these years and I'm sure I have missed something or messed something up . Thanks .
Also I have a old turbo link 2.1 that I need to figure out how to link to a serial to USB converter which I have had no success with on my other cars. Again thanks.
