- Sep 1, 2008
Morning to all the gurus here in GN world my ? Is I'm out driving my car an gave alil gas an boost an at 15lbs of boost my gn back fires an if I put my foot in its azz at 15lbs its surgging. What could this be?
SignUp Now!I have an 87 with about 30k on her. Just did a complete tune, wires, plugs and fuel filter included. Car runs a bunch better but stiill backfries a little and I'm afraid to punch it. I did get a replcement MAF a few years back from Kirban. I'll check the wires again but what else should i check out?
You can ohm out the coilpack with a voltmeter, front to back, should be between 11k-13k ohms. You have to take the cam censor cap off and you will see the tab, make sure it did not loosen up.thanks Turbojd. What do i check on the coil pack? Where is the cam sensor ring, sorry for the non mechanically inclined questions.
