Just converted from a sequential DFI to a speed pro. I also went from 72# to 83# injectors on my stage 1. I installed the Speed Pro and retained the jumper wire from the MAS to the Map. I received a 83# program from Jack Cotton via e-mail and had problems reading what he sent me (series of numbers and symbols). I installed the program anyway and checked the setup parameters which showed the crank ref. angle at 10 degrees and the firing order set at 165432. When I was online the spark advance showed 30 degrees with the key on. Tried to start the engine and it cranked for a few seconds then a loud backfire. I checked the spark plug wires (they were removed when I replaced the injectors) and the connections on the speed pro.
Any suggestions?
Thanks,
Jeff Rand
Any suggestions?
Thanks,
Jeff Rand
