Backpressure Sensor
I misread this earlier. I really don't know what the backpressure ranges will be on my car. I know how much c02 I need to make what Boost I run, and it's a lot. A whole lot.
45 pounds of c02 to make 28 pounds of intake boost.
This is going to be interesting. I was running 36lbs to the wastegate to run 29psi with the old 7675 turbo, and I have a 4lbs spring in the gate.
Ok maybe I'm misunderstanding I thought that the more back pressure you have the harder it is to control boost like as in lower boost levels not higher maybe I'm misunderstanding
More backpressure pushes harder on the gate, I have trouble keeping the gate closed enough to build boost. It's a balancing act.
It's honestly a balancing act. There's a lot of factors that go into it.
I will. I hope to test this month. Waiting on plug wires and a hood right now.
