Member # 77
- May 26, 2002
Since I was confused on Backspacing of a rim I thought I would post this for all the other rookies on the forum.
Thanks to jdpolzin for setting me straight on it.
How to Measure Wheel BackSpace:
Items required to measure wheel backspace:
Tape measure
Straight edge
Wheel w/o tire (preferred)
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
Info came from:
https://www.rsracing.com/tech-wheel.html#backspace
Tape measure
Straight edge
Info came from:
