BlackMetal
- Sep 29, 2005
Well I just crunched the actual numbers instead of estimating, and if you went with the 3.5" backspacing in the front, the lip would literally be about 0.01" bigger than the rear. I don't think you, or anyone else, would be able to notice the difference and tell that the front had a bigger lip.
So if you're fine with having the lips look the same size all the way around (and you were asking about using the same size for all four corners in the first place, so the lips would have all been the same), I think you can pull it off with the 17x8s (3.5bs) and 17x9s (4.5bs).
Geez...after all that confusing math, it seems pretty obvious looking at the numbers I just typed.
The rear wheel is 1 inch wider...but also has 1 more inch for backspacing, so the outside lip of the wheel is going to appear the same. Durrrrrrrrr. :redface:
