BAD FPR?
klmnla
Watson LA
Is it possible that the FPR could cause too much fuel pressure during WOT? I noticed that I start out at about 42psi, and when I hit 15lbs of boost, the fuel pressure is hitting 60psi, and the BL drops from 128 to about 115-119, as if there is a rich condition. Anyone seen this? I was testing it out after adding 5 gals of 112 race gas to about 10 gallons of 93 to see if my miss at WOT would get any better. Nothing has worked yet. I have minimal KR at WOT, but have to roll into it until I get this missing at WOT fixed.
"Start out at 42". Is that what the fpr is set at w/ the vac hose off/plugged, or with it on?
Yes, set at 42 with hose off, and idles at about 38 with line on. Rises with boost, just seems it goes a little high, possibly causing BLM to go a little low.
I think using a wide band would be much more accurate at determining what's going on. The further from Stoic the NB gets, the less reliable the reading.
