- Jun 18, 2001
Okay, just limped my car back home from Atlanta (see the southeast forum for mild details).
Basically, the story is this: Car ran fine on the way down, got to tech inspection at the event I was entered, guy shook the MAF real bad, car starts hesitating and popping and sputtering whenever you give it a good throttle input.
Changed fuel filter. No change.
Got in touch with Dana Wyatt, he didn't think it was the MAF. We checked the coilpack (what its doing feels like its hitting a spark-cut rev limiter... at 3000 rpm). Bad center coil (and the fouled plugs to prove it.
Okay replaced the coil, two fouled plugs. Runs much stronger until it cuts out again.
Switched out ignition control module. Same problem
Disconnected cam timing sensor. Same problem
Disconnected MAF. Same problem
Changed out all the plugs and the plug wires. Same problem.
Suspected plugged CAT, cut it off. Same problem.
Gave up and limped it home.
So, I just hooked TurboLink up to it. My TPS is set fine and registering throughout the range. The MAF is giving me a signal at idle and on-throttle (not moving). O2 is working (cross counts are good). I suspected possibly fuel pump, but I've hotwired it on and run it for ten minutes without hearing a stumble or seeing a variation in pressure on my gauge (rail mounted, can't watch it while car is moving). The system is holding pressure after turning the car off, so I'm not suspecting a leaky injector yet.
On the road, it will maintain a constant throttle setting, but ast soon as you tip in, it cuts out.
Gas mileage was around 17mpg on the way home. I'm running stock injectors and chip, fuel pressure is set at 40psi.
I'm getting a new inlet tube welded onto the cat so I can put it back on and not annoy my neighbors when I take it out for a load test, so no tests with it actually moving until probably tomorrow.
It is running rich. Very rich. Off-idle O2 millivolts are in the mid 800s, and on the way back from Atlanta, the thing let out some incredible backfires. Popped it right next to some lady in an SUV on I-24 in Tennessee and she almost swerved off the road.
I'm still suspecting the MAF. I've found a couple posts describing similar behavior, and the fact the problem started right after that dude shook it kinda keyed me in. I'm waiting on a translator and a 3" Declo LT1 MAF right now.
In the meantime, what I can I check? Cam sensor alignment? Crank angle sensor? EGR?
Thanks in advance!
Thanks in advance!
