this is my last resort guys . ijust don't have any other ideas. Ihave 87gn heavily mod. Ihave recorded multiple runs on direct scan in my garage w/ e-brake. i bring car up to 2400-2700 rpm 2-6lbs boost if that . starts to break up and pop but no backfire. the warmer car gets the easier and quicker it comes in even at 0 boost. idle is rough most of time. i have twk alc chip in now but also i try to put full thr. ext/pro chip in and soon as i put car in gear that chip wants to die so im using the turbotweak chip for now since the car will run. direct scan shows all vitals look great except the o2 values go crazy when sputerring starts but i think this would only be normal. here's what ive checked so far
bypassed dis4
plug+wire swap
coilpac swap
ign. mod swap
put stk maf back on instead of 3.5 ls1
swapped main computer
tryed all 3 chips i have
fuel pres. at wot holds good
plugs look good
readjusted cam sensortwice with caspers tool
checked cam sensors ring and cap ok
i fixed exhaust leak at croossover on my hye tech per. headers
i actually thought this was the fix but it wasn't
could it be head gasket?
i also thought about crank sensor but i think it wouldn't run and its not loose.
tps has no dead spots
maf goes up steady
voltage holds at 13.7 -14.3v
one other thing i noticed is when car is really warmed up on the road 10-15 mins driving that overdrive will really make car vibrate and shake until i put it in 3rd then its not as bad. this could be related but i thought this was strange.
but never no knock on direct scan or scanmaster ANY IDEAS
bypassed dis4
plug+wire swap
coilpac swap
ign. mod swap
plugs look good
maf goes up steady
