Bad idle when warm outside
MauDeuce50
Need Rehab for Boost Addiction
When it is warm outside the idle is terrible. It will fluctuate from around 2000 to 500 or 600 rpm and will cut off sometimes. I have to wait a few minutes to put it in gear or it will shut off as soon as I do 75% of the time. This only happens when the car has not been driven for a few hours or more. It is worse in warm weather but still not great in cold weather. Also the BLMs are high at 150. Will a cracked header or leaking vacuum tube cause this or are the BLMs a separate issue? Im still learning the ropes of the TB world and any advice is greatly appreciated.
