3
34bud
Guest
85 GN JUST REPLACED- NEW WALBRO PUMP-HOT WIRE/NEW GREEN STRIPE INJECTORS/NEW COIL/MOD./NEW FILTER/ ADJ. FUEL REG./ NEW PLUGS/WIRES/ PROBLEM? WITH THE OLD INJECTORS I SET THE FUEL PRESURE @ 30# WHEN I PUT IN THE GREEN STRIPES IF I GO OVER 20#-25# WITH THE VAC. OFF AND I GET INTO IT HARD BLACK SMOKE AND A BAD HESITATION. AT THE LOWER PRESURE ITS FINE? ALSO AT A IDLE IT SEARCHES. I HAVE NOT REPLACED THE ORIGINAL CHIP.
