72firebird
- May 18, 2004
Well I tried searching but it doesn't look like the search is working. I've been having a problem with my car making it up into the RPMs under boost. Under WOT it gets to about 14psi and about 3,500 rpm and then it pops and pretty much dies and falls on its face. It smokes alot but there is no knock and is running a little rich (O2s around 810mv). I was wondering if it might be my valve springs. The BLMs at idle are 145 and WOT is 128. I plan on taking the valve covers off this week but would like to know if it's possible to be my problem.
If sounds liek it is valve springs what should I go with the 100lbs or the 110lbs LS1 springs? Also what cam would be good to go with for my combination? Anything else I should do while I'm doing valvetrain work (pushrods, lifters, rocker shaft)?
