Ken Cunningham
Post No Bills
- May 24, 2001
Why does my Regal overheat at idle?
The radiator is one-year new, filled with distilled and RMI 25. The thermostat is a 160 and I monitor the temp with a vdo gauge.
Normally it will run below 160. Only at idle, I see the temp needle run way up near 250. Putting the car in N and gunning the engine usually helps reduce the temp. Turning on the heater also helps.
Is this a typical failure mode for a water pump? Does a pump get lazy at circulating water? In the past I have only replaced pumps when the bearing became loud or the pump seals leaked.
The heater control valve show some discoloration like it leaks, but I don't lose much coolant. Even after showing 250 on the gauge, I don't notice any boil over, so it may be that the gauge is screwy. But the symptoms are pretty consistent and I don't want to risk my engine.
