Baffled catch can breather kit 12 an
turbo96max
Selling a black powder coated breather catch can kit. Can has 2x 12 an ports and one 10an port. The cab is baffled , with filter breather. I had this for my valve covers and the 10an port to the lower intake pcv hose. I welded a 10 an bung on the intake.
I went back to breather filters only as I’m troubleshooting stuff and need to clear up engine bay space for now. If interested I maybe selling my ported intake w the already welded bung.
I will include the diy bracket I made to bolt it to the radiator support, hoses and fittings . Each 12 an jose section is about 5ft long.fittings at valve covers are 90deg. Straight at the can. So plenty to trim to fit where you want it. This was used for almost no runtime.
Not sure where to price since it’s somewhat custom piece but it’s OBO
$200 shipped
So you had AN fittings welded to the valvecover breather ports, and then ran hose from those fittings on the VC's to this catchcan?
Are you selling the VC's you used as well? What type of cylinder heads were they for, if you are?
What size is the catch can? (how much fluid can it hold)
What are the dimensions of the catch can / bracket / breather?
Thank you,
Tyler
Correct . I will get dimensions and fluid capacity and update the post. Pm you on the valve covers
Pics of size. Will make time to try to get a measure of fluid capacity
