BlackMetal
- Sep 29, 2005
It didn't even occur to me until today when I started balancing my new wheels at work that I didn't know how to do it on rims with little to no offset. I work for Toyota and I'm used to balancing wheels where the center mounting face is offset all the way to the outside of the wheel, so if you want to use sticky wheel weights you just hide them behind the spokes and you're set. But on my new wheels with a lip on them, I realized it wasn't that simple. If I tried putting the weights behind the center face of the wheel, it would just ask for more weight in different places because it wasn't truly a weight on the outside of the wheel, due to the lip.
My only idea was to put it back on the tire machine and use the bead breaker to pull the tire down enough that I could stick the weight on the INSIDE of the rim. It worked on one wheel, but the second rim wouldn't cooperate, every time I threw it back on the balancer I'd hear the weight fall off and bounce around in the tire.
I guess since it's the inside of the rim I could rough it up with some sand paper and get it to stick better, but I thought I would ask here first.
Is there a "right" way to do this? Should I just get them as close as I can and hope I don't feel any vibration? My idea of sticking them inside the wheel seemed like it might be the only way. Even the more experienced guys at work didn't know what to do, they said with wheels like that the only way you're going to balance the outer lip is with the traditional weights that you hammer on, which I obviously wasn't going to do. Need advice.
