could someone set me up with a base map that i can do some fine tuning to for my BBC?
Here's the specs:
533ci
dart pro 1 heads 2.5x1.8 rectangle ports 2.25 intake valve
cam is 244/256 @ .050 .632 lift
9.2:1 compression
blower is not on right now.
also, no matter what I do, my spark timing will not drop below 30* advanced, its not locked out, and i can adjust everything, but i have phased and rephased the rotor several times in DIFFERENT positions and still at 30* advanced, ive tried entering 20* into the crank offset in the config, but this had no effect after sending to ECU no matter what number i tried.....am i missing something about how to set this or is something other than my thoughts broken?
Here's the specs:
533ci
9.2:1 compression
