Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
thinking what you have is basically a stock motor with maybe some bolt-ons....
replace the oversized fuel pump with something more appropriate. see post 35 in the linked thread.
any 255 ltr/hr pump like a Walbro 340 or DW200 would be fine. Also, any 215 ltr/hr pump like the Walbro 307 would be OK as well. they cost the same. see post 35 where I list vendors and cost.
have to remember that fuel pump must flow enough fuel at pressure to satisfy engine demand. baseline fp plus max boost psi equals fuel pressure needed at regulator. pump output decreases as fuel pressure increases. starting with a baseline so high, not so good.
replacing a fuel pump is easier and cleaner that buying and installing a braided line and fittings to replace the return line.
