Hi Buick Brothers,
I have a Syclone with a TE44, upgraded IC, and run the Ford 36# injectors. I just installed the SMC alky kit and filled the canister with denatured alcohol. I went to the track last night and my times were a little off but not by much. With only 3 runs it is hard to get in some serious tuning. I brought the alky in at 12#'s and had the pump speed at 7. It seemed to lay down in 3rd gear, as evidenced by my mph (12.53 @ 107) I cooled the truck down, then lowered the fuel presure 2#s and also the pump speed to 5. The truck picked up 2 tenths (12.33 @ 108.59) but I had to let up some, as the EGT's rose suddenly about 100 feet from the lights. On the 3rd run I brought the FP back up 2#'s and again slowed down correspondingly, but the EGT's stayed down. I was running 20#'s of boost on all runs. What kind of advice would you guys reccomend for some basic tuning of alcohol, in other words, what works for you? When I increase pump speed should I decrease FP or turn up the boost? 20#'s is the most I normally run. I did a search and but did not find much info that helped. Any help would be appreciated.
Thanks in advance,
Mike
Thanks in advance,
Mike
