wickedtt said:You say its a Pro-Torque converter which on 12 inch or the 10.5 ? Did you
buy it direct from them or used?
I bought it new from Cotton
18343
PTC 12000 HS
Are the numbers written on the box, it is a 12 inch with lockup.
SignUp Now!wickedtt said:You say its a Pro-Torque converter which on 12 inch or the 10.5 ? Did you
The 12 inch doesn't come 3200 stall like in your signature .. I have heard of the 9.5 ballooning but you would have to remove it and see .Mad_Trbo said:I bought it new from Cotton
18343
PTC 12000 HS
wickedtt said:The 12 inch doesn't come 3200 stall like in your signature .. I have heard of the 9.5 ballooning but you would have to remove it and see .
Razor said:The 9.5 ProTorque comes with the anti-ballooning plates. The 12 inch doesnt, actually no 12 inch does. And you would need to see if there is an issue with the hub of the TQ converter where it goes into the back of the crank. Crud/debris could be there not letting the TQ converter move back and forth on the "flex"plate.
The 12 inch converters are like 2800/3000 stall.
On my car it would set off the knock detector at 2500 RPM's between shifts. At wot it would not knock. Had a sorta dieseling sound.
See if the other half of the main cap has identical wear. If so, the crank was pushed forward. And time for a converter inspection.
I ran a 12 inch ProTorque on my first TTA for like 500 passes.. never an issue. I killed 4 transmissions and had a local shop cut it open and clean it out a few time.. never an issue. Used and abused.. I wouldnt hesitate and buy another, hence why I run a non-lockup in my current car.. ProTorque.
getchasum said:Look at the top thurst bearing also to see if the wear pattern looks the same as the bottom half of that shell. Could be that the crank was not indext prior to tighten of the main cap, that's if your lucky. BUT with a billet main cap & a thrust problem, I bet the problem is with the machine work in the fit of that cap.
getchasum said:Experts, Is it just me in wondering why the wear does not extend all the way to the parting lines of the bearing shell, it also extends longer on one side and showing heavier wear on the other side or is there small ramps in that area of the bearing creating the shadow I'm seeing? To me the wear pattern in the pic makes it appear that the cap was cocked due to misalignment. (Could be from crank not being index correctly or machine work, I'm betting on the 2nd due to the billet caps)
If I'm wrong here someone please point it out but.....
Anyway you go I'd think that top bearing shell needs inspecting. So at this point I'd be deciding if I was going to pull the engine or bring the bearing out the bottom. Once you get it out...you or have someone do a good inspection of both shells to check wear patterns. If they look the same THEN move to looking at the TC.
Mad, just wondering had you lost any oil psi yet & what was it prior?
BTW....what advise is you competent vendor giving you?
Mad_Trbo said:Here is the other cap
When we use the word indexing, what does that mean?
EightSecV6 said:From the 2nd pic, it looks as if it were punished pretty good as evident by the material transfer to the cap FROM the block.If BOTH engines had thrust issues (which is what it looks like from the pics), your trans/converter is in trouble or not enough clearance between the fw and conv. Alot of foot brake/transbrake action will cause this too, it puts a tremendous load on the thrust. The different color on the bearing looks like it was either caused by the excessive thrust moving it around and causing it to loose the "oil wedge" as the crank should never come in contact with the actual bearing surface.Basically the best way to index the cap is to tap it into place with a deadblow hammer, torque all nuts to 50ft.lb. and then loosen them up. Thrust the crank forward with a dead blow hammer from the rear flange,then thrust is backwards from the snout with a deadblow and then back forward again. Retorque all the nuts (ARP studs) to 105ft.lb. and check the endplay with a dial indicator.
JoelGN said:Mad TRBO did you examine the top shell of the thrust bearing? Have you found anything that points toward crank thrust surface, improper seating or TC?
