m3x1c0
Bad luck Buick
- Jun 16, 2014
Hey all, I was replacing the fuel filter and it turned out to be the biggest pain in the ass I've had in a long time lol! Basically the lines going to the filter are angled so if I get one line threaded into the filter the other is super difficult to get started since the filter is pointing toward the ground slightly. I am pretty sure it has something to do with this:
As you can see thats the inlet to the filter and its pretty tweaked. I highly doubt I did this without noticing while putting the filter on but I will measure fuel pressure today to double check (I assume it would go higher if this kink was new.) Is this enough of a bend to be concerned? If it needs replacement is there any upgrades I should do while here? I have been wanting to go with AN fuel lines for simplicity. Could I go with braided line to replace or should I stick with stock hard lines?
