Best 3.8 engine builder in Austin, TX area?
GlockandRoll
Killed my stock power-plant - or so it appears.
I do not plan on putting it on a track, but would love to give the motor some more balls, as long as reliability and durability is the main focus.
Your recommendations are appreciated greatly!
Thanks!
what kind of hp are you looking to get out of your car inthe long run? i can help but im in houston:redface:
just looking for a street motor, something fresh and robust. not going to weld a cage in or notch the frame, or anything like that. I'm going to pull the heads off this week some time and see if it's just the gaskets.
maybe someone else will chime in, but i know brian at T's machine in north austin has done quite a few turbo buick engines (including mine about 5 years ago). He used to build engines for a lot of the local guys, but im not sure if he still does anymore.
-Jeff
-Jeff
Do you have his contact info for the shop, I'm not familiar with them?
