87buickregal
- Dec 2, 2003
Guys, I have a 99k 87 T that has a few things like MAF pipe, K&N, adj. fpr, new O2, plugs, wires, etc., mostly stock. I plan on getting a walbro 340, new injectors, turbo, maybe big neck, chip, scan master, boost gauge, and valve springs. My question is what combination of injectors and turbo would be the best for the street on 93 octane given my stock heads and stock stall? I'm thinking something along the lines of a TA 49 or TE 44 (is there a big diff. between these two?), and maybe some 42 # injectors with a chip from Eric Marshall for this combo. What do you guys think? Anything else I should consider or I missed there? Also, since this is my first time doing a fuel pump on these cars, what method do you guys use to drain the tank? Thanks.
